Does anyone know how to lock images in Freeway Pro to stop them from being dragged off the website when uploaded ?
many thanks
Jill
actionsdev mailing list
many thanks
Jill
There is an action for that:
http://www.freewayactions.com/product.php?id=006
However, if you don’t want it copied, don’t put it on the internet. You could also try applying a watermark, adjust compression to a point where the image quality is tolerable, or upload it to a size that’s not useful to others.
The very essence of the way the web works is that the client machine (ie the one with the browser) downloads a copy of the image to display it. If you try to stop people dragging the image off the page, a simple look at the page source will give its location and it can be got at from there. The Action may stop the casual pilferer, but the more dedicated types will be able to access it by other methods.
