[Pro] Locking Picture
Is there a way to prevent someone from saving a picture from a site?
I want to disable right click on a picture so no one can save it
I will tell you up front: this is an arms race that you cannot win. In order to show a picture to a person, you have to make it visible, if they want it, they can screenshot it. No, you can’t block them from doing that. Tim Plumb has written a very nice Action named Image Guardian, you may want to use it (particularly if this is a client request, and you can’t disabuse them of the notion). http://freewayactions.com for the details.
If they can see it then it means it has already been downloaded to their computer.
So anything you try is a waste of time (and your clients money) - if they don’t want it downloaded/saved then don’t put it online in the first place.
The Image Guardian Action is not FW7 compatible.
I’ve tested the Action with Freeway 7 and it appears to work as described. If you’re having issues with it please feel free to get in touch;
http://www.freewayactions.com/product.php?id=con
