You really ought to put those into some sort of pagination, maybe stick to 5 articles per page, with a link to “older” articles below that. That will get your total page height down to something manageable in Freeway.
Also, could definitely benefit from putting each article in its own container, then each one can have an H1 in it without creating a confusing document tree. This would make your archiving process a lot easier, too, since you could click to select the last item on the page and cut it to the clipboard, and then paste it into your top-level section container on the next page, and so on.
But really, if you are going to be blogging like this, static in Freeway, you’re going to need to come up with a better way to compose your posts together, so you don’t end up with a heavy manual process required to manage things. You should definitely look at Perch for this, or another database-driven CMS, since that will allow you to abstract the content away from the presentation, and sort and re-present the content in multiple forms without requiring any manual effort on your part.
On Mar 3, 2014, at 12:59 PM, Wimdg wrote:
Walt,
Here is the link:
http://www.appadvies.nl/appblog/blogartikelen-2012-no1.html
Total page height is 22000
The reason I am doing this is to combine blogarticles. I normally have one blog per page. But I find I am collecting too many pages now. I am blogging 3 times a week now and publishing al lot of pages is not very fast…
