That’s me you’re talking about? Gosh - indeed I write often confusing things - but not about this specific topic as far as I remember.
And if you’re talking about:
http://www.test.q-ring.de/follower/pages.php?DOC_INST=9
it is more to be seen as a test than a roll-out template or even a tutorial. And furthermore it is just a way I did and there are probably better ones (or even Freeway friendlier ones).
Furthermore, DenimWashed deals with external scripts where I haven’t got a developer-licences.
That’s what I did (in brief):
REQUIREMENTS:
- A RichText-Editor
- A basic understanding how to deal with external code
THE WEBYEP PAGE:
A RichText Field in a loop
the WY-SEO menu with the script part enabled.
SERVER SIDE
I put manually the required script parts into the opt folder of the web yep system.
This is mainly following the instructions on:
http://kolber.github.io/audiojs/
THE IMPLEMENTING
can be done either in the Freeway-File or even in a doc_instance. The required code-pointers to the scripts on server and the function call belongs either into the before end head tag of the FW page or can be inserted into the script part of the SEO menu bar.
Up to here I can remember but honestly I’m unsure what I did then. As an Image/File Manager in TinyMCE I use tinyBrowser. This is difficult to recommend cause it needs some server-site requirements that are not always available (such as CHMOD777). This enabled me to upload the files even with TinyMCE.
But probably it even works with the standard multimedia tool (in TinyMCE) without that special feature.
So as you can see:
It sometimes takes one long to figure out, much longer to fiddle and finally hours to document it - and honestly I have not the time to do currently.
Furthermore I wait on Max and his review of the webyep system where he wants to implement redactor as the text-editor. I am pretty sure that things will be much easier then (probably).
Hope this helps you out.
actionsdev mailing list
