[Pro] looking for an action for 'swelling' a picture
Greetings.
I am looking for an action for Freeway Pro action that would, when scrolling over graphic, cause that graphic to increase in size by a certain percentage.
It would swell the graphic and move other thumbnail graphics that might be next to the swelled graphic, push them out of the way.
Not sure if this is possible in Freeway, but I did hope that this would be something possible to do.
Thanks for any ideas…
Sam
There’s nothing like this in an Action, but you are describing what is
widely known as a “fisheye” or “dock” effect. Have a google for one of
those. You’ll need to construct your set of images as inline images in
a larger HTML box. Draw a box where you want the effect to happen,
then double-click that box so you see a flashing text cursor inside
it. Then choose Insert / Graphic Item from the main menu to insert
your first graphic container. Click on that box and import your image,
then double-click the HTML box again and repeat until all images are
there. You can space them apart using margins (set that in the
Inspector). When you make your images like this, they will naturally
“repel” each other as they grow and shrink.
On May 26, 2009, at 2:01 PM, sampolfonz wrote:
Greetings.
certain percentage.
