However the hardrive I was working from has since become corrupt and contained all the original FW files, site folder the lot!!!
Can I suck the site and re-use in FW?
Or use the FTP to drag the html files, resources etc down and re-use in FW?
If this can be done - my life is worth living!!!
If not I can only hope I can recover the data on my WD harddrive now only says eject/initiliaze/ignore upon booting up!!! I cannot access any files or the drive at all!!
Boot your mac from the latest version of Disk Warrior and repair the HD.
If you don’t already have a Disk Warrior DVD you can purchase Disk Warrior online and install it on any drive besides the one you need to repair. After it is installed on 2nd drive use it to repair the HD and when finished I would make a copy of your data just to be safe.
Dale Josephson
Dale Josephson Consulting
Apple Developer & Support
On Mar 29, 2011, at Tuesday9:26 AM, Mr worm wrote:
I have builta site anduploaded it via FTP.
Afraid not. Freeway isn’t an html editor. Your published site at least has all your content to follow, but otherwise you have to recreate the layout in Freeway.
You can try a disk repair utility to try and salvage your data. Drive Rescue or DiskWarrior are good choices. Have you tried Apple’s own Disk Utility yet?
