Need help. I just opened up an Exhibeo Gallery to do a little editing and my photos are missing. Apparently, I moved them somewhere on my Mac. Is there anyway to reconnect the images to the Exhibeo master file?
So that this doesn’t happen again in the future, where should I be placing my Exhibeo master images?
I’ve had the same thing happen before… Putting the images in the same
folder level as your Exhibeo project file does nothing to reconnect them,
and there is no asset collection or archive feature.
Try this (it worked for me): Manually collect your Exhibeo file and images
to whatever folder you want - I create a folder in my FWP Media folder.
Open the Exhibeo file… you will see the image slides on the bottom, all
with question marks. Switch to your Finder window, grab all the images and
drag them to that slide row Exhibeo and they should relink. Check and make
sure they do.
Best of luck.
This missing images is a problem for me continually both with Showcase and Exhibeo. report to Softpress and they suggests I make an archive of each and every gallery UGH! but this feature is not available with Exhibeo, so please Softpress if you are listening…
Just started using it and alas one missing image in a gallery…
easy to fix but I really don’t want to go thru the hours of redoing galleries I have had with Showcase
I keep everything organized
thx
I had the same disconnect and found that by re-selecting the exhibeo file in the Action palette window all the images re-linked. I moved the entire site file intact and the original exhibeo files were within each page folder. Hope that helps someone else down the road.
