[Pro] Mac OS Yosemite and Freeway 5.5 Pro
Hello all
Any compatibility issues with Mac OS Yosemite and Freeway 5.5 Pro ?
Tony
The above should say Freeway 5.6.5
None that I know of. I fired up Freeways 5, 6, and 7 in Yosemite Public Beta last week and they all seemed fine.
(I have Yosemite running in a separate partition so I switch between testing apps on it and going back to my current Mavericks install. See more at the link.)
http://freewaytalk.net/thread/view/150000
Thanks for that Joe
Appreciated.
Tony
I have Freeway Pro 6 and I just installed Yosemite. Freeway doesn’t respond when I try to open it. HELP!!
Thanks anyone :slight_smile:
First thing I would do is reinstall FW.
Then check permissions etc.
I’ve just installed Yosemite and Freeway Pro 5.6.5, FreewayPro 6.1.2 and Freeway 7 all startup immediately and work just fine for me.
Thanks very much. I decided to upgrade to 7 and all is well.
