[Pro] magnifier?
Does anyone know of an action that can zoom in on text or an image in a window or circle and move with the users cursor? i.e. the user would click on a magnifying glass icon and the zoom window would appear and then move with cursor.
No actions but there are plenty of external scripts that can do this - here is one http://www.deltadesign.co/fw_examples/jQuery/rbzoom.html
Look at the motorbike in the middle of this page http://codecanyon.net/item/product-image-zoom-plus/full_screen_preview/5901974
Wow, that’s been a few years since we’ve covered that one …
Yes me too!
http://www.freewaytalk.net/thread/view/154274#m_154275
Perfect gents, Thank you!
I was able to get the script to work but I can’t seem to get the zoomed image to appear in front of the small image. Any ideas?
http://theminesoflight.com/zoomtest.html
Hi Seth, in your query.elevatezoom.js file at line 260 change
self.zoomContainer = $('<div class="zoomContainer" style="-webkit-transform: translateZ(0);position:absolute;left:'+self.nzOffset.left+'px;top:'+self.nzOffset.top+'px;height:'+self.nzHeight+'px;width:'+self.nzWidth+'px;"></div>');
to
self.zoomContainer = $('<div class="zoomContainer" style="-webkit-transform: translateZ(0);position:absolute;left:'+self.nzOffset.left+'px;top:'+self.nzOffset.top+'px;height:'+self.nzHeight+'px;width:'+self.nzWidth+'px;z-index:999;"></div>');
Matt.
Sorry and line 319
self.zoomWindowContainer = $('<div/>').addClass('zoomWindowContainer').css("width",self.options.zoomWindowWidth);
to
self.zoomWindowContainer = $(’
’).addClass(‘zoomWindowContainer’).css(“width”,self.options.zoomWindowWidth,“z-index”, 999);
 self.zoomWindowContainer = $('<div/>').addClass('zoomWindowContainer').css("width",self.options.zoomWindowWidth,"z-index", 999);
Alternately I’ll send you the js file and stop making a mess copy & pasting!!!
Well, I changed the 2 lines but now the script doesn’t seem to work…
Try replacing with js file in example download
That did it… thanks again!!
I’m back with one more question… I would like to change the cursor on the image being zoomed. I’ve added an image style pointing to the cursor I want to use but can’t seem to get it work. example here:
You will need to change the file format of your cursor image from magnify.cur to magnify.gif (or png etc)
Replaced the cursor file and the style with magnify.gif but still not working…
Try adding it to the Div - div class=“zoomLens”
ie something like
div.zoomLens {
cursor:url ('http://theminesoflight.com/Resources/magnify.gif')";
I should add that the .cur file is required for IE - an image file for most sensible Browsers
Sorry, not quite sure how to add the div class. item:extend:div?
I created a new style called .zoomLens and under extended added name: cursor value: url(http…) then under item:extended:div added name:class value:zoomLens so I must be missing the boat here…
another observation… it seems Freeway is not producing a css folder nor a stylesheet in the site folder when it publishes the site. Could this have a bearing?
