So, a little further investigation seems that using the Modernizr script may be above my pay grade…
Hi Seth have a look at test have added Modernizr
https://www.dropbox.com/s/mu85d1aqjy316eq/elevatezoom2.zip?dl=0
Thanks Matt. I’ve uploaded the modernize script and added the script code to the before section but still seeing zoom on iPhone, perhaps (most likely I added the code incorrectly?
forgot to add the link…
http://theminesoflight.com/zoom2.html
OK, sorry, I see that you had the code in the example. I have corrected mine but still getting the zoom window in iOS.
Hi Seth, Sorry didn’t really check thoroughly myself. will have a look further when I get the chance.
Try this one - http://deltadesign.co/FW7Test/elevate-zoom.html
Rather than use the ID to instantiate the zoom javascript as in the original ie:
$("#img_01").elevateZoom({
zoomType : "lens",
lensShape : "round",
lensSize : 150
I instead added a class to my image, of .zoom-me, in the same way you added the other extended attributes.
That way I can set up any image on my page with the .zoom-me class using:
$(".zoom-me").elevateZoom({
zoomType : "lens",
lensSize : 150
Now that I have a class as the trigger I can use a bit of javascript to remove the class at smaller screen sizes.
So my new html markup in before is this. What this does is look for an ID of img_01 (which you added to the original img using Item>Extended) and it checks what class attributes it has. Then if your screen is smaller than 769 it will remove the class of zoom-me which was used as the initial trigger. What this will not do is remove the class if you start viewing on a screen larger than 769 and then reduce the browser width (without a refresh).
<script>
(function(doc) {
var zoombuster = doc.getElementById('img_01'),
remove_zoom = function() {
zoombuster.classList.remove('zoom-me');
if ( $(window).width() < 769) {
remove_zoom();
else {
//Add your javascript for other screens here
})(document);
zoomType : "lens",
lensSize : 150
</script>
There are many other ways to do this - probably better ones.
Great work around Dave, this works like a charm, i can now scroll and pinch to zoom in iOS.
Many, many thanks!
how can i create zoom/enlarge feature for html images?
This might be worth a look, one of my precious video’s by Dan Jasker …
