Hi guys, I have a problem I need help on please. I have set up this shopping cart and have product variations. But now the cart does not work. When you add an item to the cart I get this message:
You currently have no items selected in your order
What can I do to fix the problem?
Website is: http://www.reppwear.co.uk/repgymwear-store.html
Exhibeo mailing list
I am not sure how you have put this together but the problem is that there is nothing in the variant selector that relates to the actual product so the form doesn’t recognise that you have selected an item at all.
<select id="item8" name="qty" size="1" required="">
<option value="Select Size" selected="">Select Size</option>
<option value="Large">Large</option>
<option value="XL">XL</option>
<option value="XXL ">XXL </option>
</select>
What method/action have you used for this.
This example uses the E-Procuct Variation action http://www.deltadesign.co/odds/tartan.html
The E-buy form action is applied to a 2 row table which contains the E-buy quantity action and 3 E-Product Variations for Style Age and Colour
Hi Dave, thanks for the fast reply.
I have made an error and didn’t even know it. I used the quantity action instead of the variation action.
I have now updated this with the variation action and this works, but I now have a problem where when the user selects one of the variations this does not update on mal’s.
Please can you have a look thanks.
Well the first one - ‘Not Big Enough’ Black Premium Fitted T-Shirts - works for me.
Might be worth removing the others and duplicating the one that does work and then alter the values to the correct item for each duplicate.
This is tricky to diagnose without the FW file.
This is what I can’t get around Dave,
Everything has it’s own value on the freeway page but ‘Not Big Enough’ Black Premium Fitted T-Shirts is being used for all the items in the cart…
If you want to get my email from my ‘People’ page and drop me a line I am happy to see if I can help you out.
A copy of the FW file (even just the one page) would help too.
