[Pro] mals e commerce
Does anyone know of a good tutorial for setting up the cart with electronic downloads with mals e commerce. I can get the cart to work but only if there is an actual product. Or if anyone can tell me how to get my cart to work with electronic purchases.
Well, I recommend using LinkLok for Mal’s E-Commerce found on the Vibralogix.com website as that is what I use on my site to deliver and manage electronic downloads.
Product Page: http://vibralogix.com/linklokme/index.php
If you follow the instructions you’ll be up in a few as this is the easiest script I’ve ever come across…if you follow the manual.
