[Pro] Mals - Running Total - Can this be done?
Hi All
From a Mals Form I would like the customer to see the running total at the bottom of a list before they click the buy button.
If you have a look at this page
http://www.orionoptics.co.uk/sigma.html
I have the example set up.
When a customer makes the various selections by ticking the boxes I would like to see the accumulated total where the red arrow is.
To the right I found this script using a google search. It adds up amounts entered and shows it in the bottom box.
Ideally I just want the total to appear at the end.
Is there any way I can use the tick boxes im my Mals form to show a total amount.
Have a look here: http://www.tne.co.uk/mals/
Loads of example Mal’s scripts to look at including showing the cart contents on the page
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
On 9 Aug 2010, at 17:45, t50ufo wrote:
Hi All
Hi David
Thanks for your reply.
It looks like the running total script is what I need.
If I could just get my head round how to implement it in Freeway!
Yes - I know little about code!
Regards
