AW1
(AW)
July 3, 2014, 3:44pm
1
I have my margins around the graphic items set to 20 yet when I publish, they disappear. Let me know if there is something I can do to fix it. Thanks!
http://www.annieweatherwax.com/savedate/nysavethedate.html
Joe2
(Joe)
July 3, 2014, 4:06pm
2
Looks like a bug in the Create Email Action. An alternative (that will actually work in more email clients) would;d be to set a right padding on both the images.
Hope this helps,
AW1
(AW)
July 3, 2014, 4:20pm
3
can you tell me how to do that.
Joe2
(Joe)
July 3, 2014, 6:15pm
4
Sure, select the image and in the Dimensions section of the Inspector palette choose Custom from the Padding popup. In the dialog that appears, set the padding right to whatever value you were using for margin before.
