HI,
Does anyone know why an embedded item using Markup item cannot be inserted into a table cell?
is this possible?
Barry
You can insert a Markup Item into any Div, Table etc.
What exactly are you trying to do - and can you share a link?
Dave,
I am embedding new polls as individual items. I want them all on 1 page.
I do not want them to run into each other so I thought a table could help with the structure but they do not show when I put them in the table cells.
you’ll see what I mean
http://hoffkids.com/polls.html#hwclub
So what code are you trying to insert?
the same one that produced the polls you see at the top. The ones you see, I simply went to INSERT, markup item, and pasted the embed code.
But then
I created a table, inside the table I went to insert markup item and it appeared again, I pasted code but no polls show up at all when using the table
i noticed when I click on the markup item that I put inside the table, it does not show me the dimensions and other information of the markup item in the inspector.
it looks very simple
Because it is just code - not an actual thing with dimensions.
i will make you a vid…
I wont get to see it tonight - bed time
But as you see from my example it works.
You can only have 1 incidence of each poll on a single page - any additional ones wont show.
oh- got it. that is why not showing.
Thanks.
sonjanna2
(sonjanna)
April 28, 2016, 5:47am
14
Hi David,
this is a nice example http://www.deltadesign.co/FW7Test/equal-height-columns-with-sticky-footer.html http://www.deltadesign.co/FW7Test/equal-height-columns-with-sticky-footer.html
of equal height columns with a sticky footer.
I only skip in here, because it would be very interesting to know, how you did this exactly.
I just wonder, if the FW-file is perhaps available?
Thanks a lot,
Hanna
