Hi I’m trying out rotating text and have placed the spans in a markup item the text is centred but this dosent seem to take account of the markup spans.
How did you incorporate the code into your FW doc?
Regards
Mark
I added the text in a markup item then there is a rt.css file and the java script is in the html markup section. if you look at page source of my link above.
Thanks for that Matt, i’ve been having a play this afternoon and by combining your method and using the external CSS and external javascript actions I have managed to also trim down the page code.
I downloaded the source files from codrops via your link and referenced the .css and .js files from the actions.
Thanks for you help on this.
Mark
On 13 Apr 2015, 9:47 am, Matt wrote:
Hi Mark, Thank you!
