Don’t think there is only one way to do things… keep in mind that Freeway
Pro is a code generator, and the only reason for doing anything a certain
way in FWP should be to make it generate the code you want.
PS. I think your header is fine
On Thu, Jun 28, 2012 at 1:05 PM, RavenManiac email@hidden wrote:
Thanks Ernie. I’ll do that now.
So, as a rule of thumb, is it better not to use an inline design layout
for the header (i.e. the section with the CSS menu)?Unfortunately, I converted from a standard FWP layout to an inline
construction midstream and the one thing that is not inline is my header
section. What that means is that changes, like the one you suggested to my
CSS menu, are relatively easy. Whereas, if they had of been inline I would
have had to cut and paste a bunch of menus.
