[Pro] Master problems
For reasons that I cannot figure out, I continue to have problems with pages losing the connection with the master page. When I check the inspector, Master Content and Master Style are unchecked. And this is after I have made sure that each is checked appropriately for the given page. When next I perform some edits, the check boxes are unchecked.
The only thing I can think of is that this site, unlike other sites of mine, is encased in an HTML object in order to form a border. It seems that what ever html, table or graphic object contained within the page will not reflect changes made at the given Master Page.
These problems have only cropped up after the last Apple update to 10.5.7. Or so it seems. Any suggestions or feedback would be appreciated.
http://handtoolmakers.com/
Thanks, Gary
I believe I have part of my answer. I created an html item to encase the entire page. So anything that I add to that page, once the master is used to create the page, will erase the relationship of page to master. Guess I’ll have to create a separate banner html item and a separate content html item, each with 3/4 borders, slap them together to create the semblance of one large html item with a border. Pity.
