how can I create a membership login/area for my customers on my new website?
That totally depends on what you want to do with the log in information/user once they are in there.
Is it just to create pages that are only accessible to your members or will different members access different content.
If the first then using a cPanel feature ofPassword Protected Directories can allow you to designate a folder on your server that requires user/pass to get in.
If the latter then you may well want to look at one of the custom scripts that are readily available.
More info and we can advise better.
Thanks for your fast reply.
After login, the membership users should be able to use a database for members only. Also to add their personal info onto a profile.
Thanks for your help.
HK
The letsplaytennis.com site doesn’t appear to be a freeway built site? And has a login already!
If you have the budget you could use Sitelok which has instructions on how to use with FW
http://www.vibralogix.com/sitelokpw/
