Anyone may know how to create a member login box with password?
I would like to clients who would like to use the site to do a sign up and have a password sent to them and then use the member login to access the site.
Thanks for the link. I took the time looking at the product (Buy Membership Software and Systems Online UK | Vibralogix) and my question is: have you purchase this product? I also notice it works well with HTML & PHP Pages, but all my design in freeway pro is done with CSS turned on?
Yes I have purchased Sitelok. FW is still producing html pages even if the CSS button is on. There is a lot of info in the Siteklok manual - download and review it from their website before you commit to buying.
Correct. CSS is just a particular kind of formatting instructions
that help control how the HTML content looks. Without content there’s
nothing for CSS to control!
Thanks Guys for the info. Helveticus, I just gotten a reply from sales and here is the reply:
(Hi Louis,
Thanks for the enquiry.
I must admit I don’t know much about Freeway Pro (I currently use
RapidWeaver on my Mac) but I do have some clients using it. Once
installed on your server to protect pages you need to do the following.
Change the page extension of the pages that are to be secured
to .php. This won’t have any effect on layout etc and CSS will
continue to work as normal.
Add the following (or similar) lines to the very top of the page.
This has to be before the in the page.
For a basic installation that is about it really. Your layout and CSS
should be fine. Let me know if you have any questions. If you would
like to try out Sitelok then I can email it over if you wish.
Adrian Jones
email@hidden )
My question you as a Freeway User, by changing the page extension wouldn’t that mess up my links when I make changes to my local drive in freeway then publish the updates to the server?
And, the third party shopping cart I will be using (http://www.e-junkie.com) is the login I am trying to perform. e-junkie.com does not have a login commend to place on my page before a buyer decides to add to cart - so that is why I am looking at Sitelok.
Do I change the pages within Freeway? And since freeway does not show the HTML code how do I go about placing the
You should ONLY change the file name suffix from within Freeway.
NEVER do this by going into the Site folder in the Finder and
altering the published files directly.
Freeway will manage all links for you automatically; any changes to
the file name will automatically be handled, wherever links to it
might be within your entire Freeway site document.
The process described is very easy to do in Freeway.
Step 1: use the Inspector palette to change the file name extension.
Step 2: Choose Page > HTML Markup, then pick “Before ” from the
popup menu in the HTML Markup window.
A website being built using Softpress Freeway Pro on Mac OS X reguires a password protected page or maybe two pages. Freeway has a Plugin ‘Action’ that accommodates this which needs PHP code to be hooked-up. The same ‘Action’ Plugin can be seen in use in this example… http://www.freewayactions.com/test/password/
As I am not a PHP coder, I need an example page(s) PHP protected with this ‘PageProtect’ Plugin Action, which can be freely downloaded from the ActionsForge website…
