Hi! See here
http://www.easthalldesign.com/tm2/
The SERVICES link in the main NAV has a drop down but it goes behind the Wowslider?
Please help - Would like it go drop down in front of the Wowslider please!?
The wow slider container has a z-index of 100 to lift it above other content so if you want the menu to be on top you will either need to change the Wow z-index or the menu z-index.
IT is set in the wow CSS stylesheet but to change the CSS Menu select the menu container Item>Extended and add in the name/value pair of z-index/101 to the Div Style section
Great thanks Dave I thought it was something like that… I couldnt remember what it was called or where to change.
Cheers appreciated.
