Each of my menu items links to a unique page. I can see this in Freeway on the bottom where you choose links. After uploading, however, every link just goes to the home page.
I had this happen one other time a few weeks ago and solved it by unchecking the Submit box for an item where I accidentally clicked it. I don’t have that situation now so I think that was maybe a red herring and that there’s a bug somewhere.
You rock! I assigned a link to the image AND to the text inside and because I copied the initial menu item when creating the others and didn’t change the link to the text inside, I had 2 links for each image.
This is your annual warning. Even though Freeway makes it possible, NEVER, EVER add links on graphic text by selecting the graphic text characters themselves and applying the link. Always select the graphic box (so its corner handles appear) and apply the link to the entire box. When you add a link to selected graphic text, Freeway creates a torturous image map outlining all of the shapes of the text characters themselves, even leaving holes where the counters (empty spaces in “hollow” characters" where the link will not work. This is not only maddening to look at in the code, it also makes the browser work way too hard.
