Using the Meta plus action on my site pages, working fine, publish ok still! then when I re-open file I get a Javascript error on every instance of the action?!!
I tried removing then all, re applying but still error persists?!!
I do have an EP player on the page, could this be the conflict?
What version of the Action do you have? I’ve just looked through the Action code and I can’t see how you are getting that error. Do you have a video selected in the FaceBook options?
I’m aware that the page is ‘extremely’ graphically rich… client insists! but will work towards getting all image sizes down to speed up site load times. cough cough!
Ah, this takes me back to my former days in publishing.. not so much the books but the warning about gratuitous humour.
It sounds like I may be best to see your Freeway document or at least a sample page from it so I can see why these Actions are complaining so much. I’ve BCC’d you so you should have my address in the email.
As for the page size issue here is my recently posted list of tips (hopefully nicely formatted for online viewing this time);
Freeway - set the code output in File > Document Setup > Output > HTML Code to More Efficient
Freeway - set the Resources setting in File > Document Setup > Output > Resources to With HTML Files (this will save at least 9 bytes for every image you use on the page - whoop! Still it all helps.)
ImageOptim - (http://imageoptim.com) - Once you’ve finished your site this tool can cut image file sizes down still further
ImageAlpha - (http://pngmini.com) - A great little app that will down sample 24bit PNGs to 8bits
TinyPNG - (http://tinypng.org) - An online version of ImageOptim and ImageAlpha that creates compressed 8-bit PNGs 6. Externalize - (http://www.freewayactions.com/test/externalize) - Although this Action can compress your CSS styles it may not help in loading times as the page will need to load the external stylesheet
