I have some graphics that are misplaced. They can be seen if you go to this site and slide the screen to the right and down a bit. How can I remove these? Also, does anyone have any idea why the home page is so much wider than any of the other pages.
Thx,
Steve
www.elopesandiego.com
I guess you mean http://www.elopesandiego.com/sandiegomarriage.html
Looks like you have a slideshow that is missing something - how have you built it?
I suspect it uses Sequence Timer and you may have to rebuild it.
I figured it out. I just needed to view the page at 8%. That showed me what I needed to see.
