Hi guys,
I am working on a website and I noticed that there is no resources or media folder related to the freeway file drafts that I’ve been saving in a folder. Its been awhile since I’ve made a site and I remember this being part of my previous site. Is there a setting that is off when I set up the site? I created another site from scratch to see if something was input wrong and same deal, no folders. It uploads to my host just fine. Is this a problem? Has freeway done away with these folders? Thanks.
Waylen
More likely, it’s currently publishing into the last site’s project
folder. Again, no harm there, but to fix this, go into the File /
Document Setup dialog, and look in the Publish tab. There is a button
in the middle of the screen where you set the local Site Folder. Move
that to somewhere inside your (new) project folder and you should be
all set. (Make a new folder there to hold the site, don’t just dump it
into your project folder, or you’ll have a mess.)
Freeway creates the Site Folder and Media folder ONLY when you use a
template to start the project. If you create a project without using
the template, you will need to make these folders yourself.
To be clear, Freeway has never required these folders, and their
absence just means that you know where you want to put your files.
Freeway can deal with a wide range of project file management styles,
since it tracks each file you use in your document through the Finder.
So even if you move a source file from one folder to another, it can
follow that move and not get confused. The only thing that will trip
it up (and only momentarily) is if you move a file or folder from one
volume to another, like onto a fileserver or an external disk.
On Jun 10, 2010, at 10:02 PM, Waylen wrote:
Hi guys,
Waylen
If you make a site using the Custom tab in the New File dialog you
get no folders set up. If you make a site using the Template tab in
the New File dialog you’ll get the whole folder structure thing made
for you.
I recommend always using the Template option and going with the Blank
template. Even though it is far too narrow for modern use. (Just
adjust the master page first and all’s fine.)
