Three pictures on this page. http://www.uccl.org/teenpage.html
Top pic works fine. Other two work fine in preview and when I load them to a browser from FW. On the internet they fail. Also, when uploading there appears to be a problem because they try to upload repeatedly during successive saves. First time for this problem. Previous use of Moo Slimbox has been fine.
Jacob
How are you uploading this site because there are 2 images missing from the Resources folder
I would also watch how you name your images - where does the %253D come from? Do you have a % character in your image file name? If so just stick to underscores and hyphens.
Dave,
Thanks for the tips. I renamed the files and discovered the old files were still up loading. The secondary problem was a duplicate page conflicting with Moo Slimbox. All is well now.
Thanks again,
Jacob
