Hi all
I have a simple text nav which is text which I need to create a simple pop up window in the same style of Moo slimbox style
Is there any way of creating a pop up page as such using the same style as the Moo Slimbox
The site I am creating is a simple image bank for a client as the idea is that this link is a help/contact us …
I dont want to use an image as its just text…
Its really doing my head in
Please can someone help
Stu
The Spawn New Window action can be inserted in a run of text as at http://www.deltadesign.co/fw_examples/linktonew.html
Thanks perfect but Im using MOO tools and you cant work together but its spot on thou
You did say the ‘same style’ as Moo not specifically Moo!
We cannot second guess what you are doing - only work from information supplied.
D… I wasnt having a go … its perfect advice and never knew of that action which is great … very useful tool and thank you
Stu
What are you using that is Moo on the page that you cannot do in something script/protaculous based.
Yes i forgot they cant work together… my fault …silly I should known by now… and should of said first by Spawn New Window is wicked perfect for another site …
Stu
