Mr_worm1
(Mr worm)
1
Hi Just downlaod the latest version of Moo tools from Actoins forge:
http://www.actionsforge.com/actions/view/89-mooaccordion
Downloaded folder name: 1.1p3 bf-2
When I try to apply the Moo Accordian action I get a “File Not Found” error msg?
Followed by
"Necessary support file not found in action bundle. Expected location: [[ Settings:mootoolsOptions.txt ]]
action may not function properly"
I then tried to apply the Moo accordian action, which resulted in a Javascript error msg " invalid property ID"??
I tried deleting the downloaded moo suite folder and the old - emptied trash - re downloaded files from actions forge-installed- same error message?
Am I doing something wrong or is there a file missing?
TIA
Mr_worm1
(Mr worm)
2
Ok, in my Setting folder in the downloaded files, I have 2 files:
- License.txt
- mootoolsOptions.txt
Is one missing I.E the ‘Necessary support file’ for this action bundle?
Any suggestions please?
Mr_worm1
(Mr worm)
3
Anyone ideas?
Probably worth dropping a line direct to Weaver for this one actionsupport(at)gmail.com
Mr_worm1
(Mr worm)
5
Thanks Dave, will do.
