Hello,
I made a website in 4 languages. I used the Action tool: Moo Accordion.
Herewith I have 2 problems.
The quality of the text is different from box to box, f.i.
When you click on “Meer dan 20 jaar ervaring” you see the text is clean.
When you click on “Vloeiend in 4 talen” you see a a thin black line around the letters. iCloud
Please help.
When you go to the Spanish - ES- version you will see that the text in the last box, under the title: “En Bélgica y en el extranjero” is bold and not cleanly.
This while I’m using the same text style. iCloud
I have tested this accordion in IE9 and it loads ‘closed’, when I do an accordion it loads ‘open’ - is it possible to see a screen capture of your actions pallet?
Thank you all for the tips.
My text was in html. I have made each text block in png, millions, and then I put the graphic element in the html block. Now everything looks good and beautiful. The only minis point is that the site is not so SEO friendly. http://annedb.be
Many thanks guys!
Manuela
Op 16-aug-2011, om 18:43 heeft BigG het volgende geschreven:
When the text is in html, the text is too thick and difficult to read . It looks like there’s a thin black line around the text.
Or do you have a solution?
Can you post a link to an example page? I would need to see the HTML/
CSS to figure out why that might be happening.
