[Pro] MooTools
Hi All,
I have successfully set up Weavers MooTool Accordian on a page. My question is can the contents of the lists that pop don be made to show/hide a layer on the same page somewhere or does it still not co-exist.
Mike
Unfortunately MooTools uses a javascript library that currently conflicts with the javascript library that Freeway uses for the show/hide layer functionality.
On 25 Aug 2009, 5:08 pm, scoutdesign wrote:
Hi All,
Mike
Thanks Chuckamuck. I thought that reply was coming. Does the bundled TransformFX that comes with FW5Pro allow you to do it. Or is there any other way of accomplishing this. Thanks
Say, I’m planning to work on an Accordian tonight. I was wondering if the Heads can be made to toggle? That is, if a Head’s BodyText is showing, can clicking on the Head collapse the section? As if some other Head had been clicked, except only by clicking the same head?
Thanks Chuckamuck. I kinda new that was coming. Can you accomplish it with the TransformFX that’s bundled with FW5 Pro. Or is there another way to do this?
Mike
Hi Bucky,
Yes! If you use the TransformFX action that comes with FW5 then this is how it works (by toggling). Using Mootools works in a slightly different way.
