Hiya,
Sorry, another php form issue. I have set this up with 4 possible recipients but in the php action I have to give one email address, will there be a conflict between the action and the drop-down. Also, I have sent a couple of test mails to Technical and webmaster but haven’t received them. Finally, instead of going to the success page after sending, It goes to the search result page???
Many thanks in advance
nige.
A link?
Ooops:
http://www.castlerising.co.uk/contactus.html
ta
nige
First thing to do is to take the Simple Site Search action off the page to make sure the PHPFF action is working.
We can add it back in after but these 2 dont always work well together.
Hi David,
Thanks, I’ve removed it. I think it can probably stay that way.
nige
Have you re-uploaded and tried it?
HI,
Sorry, yes, uploaded and tried. Same issues as before.
ta
nige
Still seeing the search field/action on the page. Delete it from the FW page and upload again.
Also have you applied the PHPFF Recipients List action to your email address picker?
Hi,
Thanks so much again David. I thought by adding the remove from SSS to the page that would do. Removed the other search elements and it seems to be working fine.
Thank you,
nige
If you want the search on that page as well - http://freewaytalk.net/thread/view/86077#m_92534
Hi,
Thanks for the link,
nige
