[Pro] More than one form on a page
I created a page that used a Freeway custom made form along with 2 Paypal buttons which are basically 2 forms. They ended up conflicting with each other and only one of those paypal forms could stay on the page by itself.
Anyone have a remedy to make them all play nice with each other?
Is the page online?
Typically forms should use unique identifiers so if/when used in multiples each can function independently of one another.
https://xiiro.com
Thanks. Is it tricky to give them identifiers?
I mean an id, the kind that FW adds to all its elements, which you can edit through the Inspector.
<form id=“formOne”></form>
Using multiple forms in FW isn’t difficult to pull off, but it would help to see the actual code.
I think there is a multiple form Action but I don’t know if it will be of any help with Paypal buttons.
https://xiiro.com
You can apply the Freeway Form action to your HTML form box rather than the whole page. This means you can have your two PayPal (form) buttons working perfectly. Keeping each form code separated. (Make the whole page the form means you can only have one form per page).
The slight downside to applying the Form action to a HTML box is that Freeway can publish multiple form scripts which apart from being very annoying still works fine.
David Owen
http://www.ineedwebhosting.co.uk
http://www.abcardio.org/awards/abc2015.html
Here is the page. Even if I get the custom form that I created on the page to work with one PayPal button, there is the other paypal button that needs to work too. May be too technical.
