Can I have more than one ScriptyAccordion on a page? I’m trying to do that, but it’s not working, and I don’t know if it’s because I can’t do it or if I’m doing something wrong. If I CAN’T do it, then I will quit messing with it, but if I CAN do it, then I will continue to try to figure out why it’s not working.
You are right, I can do it. I did just what you said, duplicated my
current accordion in a new page, and it worked. Turns out it was an
obvious (to some) mistake. I had p selected instead of div, which is
what I was using. Duh.
Thanks, Walter.
waltd wrote:
I just tried it in a new document, and had no trouble using more than one Accordion on a page. Do you have one working but the other isn’t?
