The first thing I would try (but you may have already done this) is to play around with the export settings to try and reduce the file size. If that’s not an option then you may want to look into using the Cloudflare http://cloudflare.com service (free and paid) to speed up load times in general. It really does make a difference though I can’t say how much it will help with your movie, but it’s worth a try. I’m sure there are other tricks to be tried and maybe someone else can weigh in.
