I wish I could read German. It looks like a very interesting system,
unfortunately I can’t quite figure out what I’m supposed to do. I did
manage to get a nice error message to appear while trying out the
controls.
Basically, what you are seeing is two things: a “lightbox” style
overlay to hold the booking form, and a “live” form with JavaScript
feedback.
The overlay is easy in Freeway: apply the PHP Make Insert Page Action
to your form page, then use the ScriptyLightbox Action to load it into
the parent page.
The “live” form stuff is more complicated. You will need to work out
what you want your form to do, and then you will need to set up
“listener” functions on the relevant form fields. These functions sit
patiently waiting, and when the form element does something, they
respond with a behavior. A good example would be the “chained pickers”
effect. (I think Dave made an example somewhere.) Choose a car
manufacturer in the first picker, then a model (from a list of all
models made by that chosen manufacturer), then a trim level (relevant
to that model). Honda : Accord : LX.
Sorting things is really simple with the Scriptaculous library, and
with the right callback functions, you can have the result of that
sort save back to the server automatically. Try this, just for fun:
Draw an HTML box on the page (in layer mode) and make a note of the
name Freeway assigns to it. (item42 for example.)
Double-click inside the box, and type four or five words, each
alone on a line. Type a word, press Return, repeat, etc. Highlight all
the text, and use the Inspector to change the paragraphs into a list.
Don’t bother styling anything at this point.
Apply the Protaculous Action to your page, and choose scriptaculous-
packed from the Library list. In the top Function Body editor, paste
in the following code.
Preview in a browser, and notice how you can drag and drop the list
elements up and down. When you are dragging one, the others will
“scoot” out of its way, similar to how the icons in your Mac’s Dock
behave when you drag them from place to place.
var list = $('item42').down('ul');
list.select('li').invoke('setStyle','cursor:move');
Sortable.create(list,{});
This is a cheap parlor trick at this point, if you reload the page,
the order will revert to the original set in the HTML. But you can
layer on additional scripts that make callbacks to the server and
store the new order in the database, or you can use the current order
of the list as part of your form submission.
On Aug 29, 2011, at 5:53 AM, Thomas Kimmich wrote:
Could anybody explain the mechanism behind and what would be the
Freeway-Starting-Point?
dynamo mailing list
