I just created a css nav bar (freeway pro 6) following the css navigation tutorial video on the softpress site. The links work but the rollover colors that I selected in the css action inspector don’t work. Does anyone know what I might be doing wrong?
Thank you for your reply. Doesn’t look like I set the rollover/styling anywhere else that I can find.
I just uploaded the revised site. The site is www.thetarotmistress.com. The menu on all pages except the home page was created on the master using the CSS menu action. I designated different colors for the Link, Hover, Click and Current page but as you can see, only the links work.
Hi Barbera
You’ve applied a colour in the inspector as well and this is stopping your roll over working if you remove .style3 and redo your menu taking care not to add colour anywhere except the actions palette it’ll work.
You were right! I removed style 3 and deleted the old menu and made a new one on the master page. Now the colors work but the links don’t. I applied the links as I did last time but when I try to preview I get the error message
ACTION CANNOT BE USED. The following Actions have been incorrectly applied and will be ignored.
Action: “CSS Menus”, Page “Tarot Services”
FYI: I was trying to publish the Tarot Services page.
