[Pro] Navigation buttons show the box when clicked on
On the site that I built all navigation buttons show the box when clicked on with the exception of the "Leadership " button.
You can see it on my server:
http://is.gd/MLE0eS
or
http://www.testingmysiteonline.com/USsite/
Is there any reason for that??? I could not find the cause of it. And there is no difference between the Leadership Button and the others that I can find???
Thanks for your help
Dan Demetriad
DEMETRIAD STUDIOS www.demetriad.com
Dan,
After a load period I see a movie in the box on Leadership.
I am using Safari at 100%
BTW - on this browser the text spill over visible in the boxes on About and Experience pages.
Frank H.
http://is.gd/MLE0eS
or
Dan Demetriad
Thanks Frank. I just received an answer from Softpress Support and I will try their advise. For anyone else interested that might have the same problem below is what they suggest:
Hi Dan,
We’ve been seeing some odd behaviour lately with rollovers and Safari 5; they seem to be working fine everywhere else (including older versions of Safari), but Safari 5 has been adding outlines to some. We’re looking into it to see if there’s something that we can change in Freeway, but it’s an inconsistent issue and we haven’t fully narrowed down if we can, or if it’s a Safari 5 issue.
The last customer that had this problem was able to resolve it by making sure that each image in each rollover was the same size and that they were aligned perfectly with each other. He also had to group the images for each button.
I would start by doing those steps and trying it out. If the outline persists, I will need to see your Freeway file so I can try some other steps and see if we can clear it up for you. The only file I need has a “.freeway” file extension; if you’re not sure where it’s saved you can save a copy to your desktop to send via File > Save As. If the file is larger than 10mb you’ll need to use a service like <www.wetransfer.com> to send it, otherwise you can attach it to a reply.
best regards,
Katie Wagner
Support Technician
Softpress Systems
http://www.softpress.com
I am still interested in other advise or opinions.
Thanks All.
Dan
You might want to try adding the following to your page in the Page / HTML Markup → Before /head section:
<style type="text/css">
a, a img { outline: none !important; }
</style>
This may help.
Thanks a lot Walter. You are always ready to help the lost souls…
I’ll try it tomorrow and let you know what happens. I guess it has to be done on each page that has navigation buttons, right???
I was just wandering, have you ever consider writing a book on “Freeway”, a real book?
Just asking. I’ll be the first to buy it.
Dan
The annals of these forums contain at least 2 books worth.
I saw this on a linked graphic on one of my pages (it was a combined graphic). Once I uncombined it, and set it to PNG, the focusHilites were gone.
Hi Dan,
