I have a strange issue where The Navigation Popup Default action does not work correctly when i look at the Site on an iphone. This all used to work perfectly but seems to have gone wrong either when i updated the IOS or Chrome may have been updated. The issue does not occur on Safari on the iPhone. I have tried more that one iphone and i get the same result and i also get the problem on another web site when viewed on the iphone, The issue is that you cannot select any new page using the Navigation menu, on an iphone when you select to change the page you are viewing the lower part of the screen changes to allow you to select the new page from the list, you can select any of the pages in your site , but because the “DONE” link is no longer shown in the lower half of the page you cannot action the browser to move to the newly selected page.
As i indicated this works perfectly on Safari on the iphone.
Any ideas ?? both the impacted sites are built using Backdraft.
thx
John
www.laconcha.ie
