[Pro] Need help, behind schedule.
I’ve built my website using FWP but took it over to DW to do some work and got the code to get the thumbnails to enlarge exactly like this when you click on the image http://www.bodylingerie.com/Vinyl-Zip-Front-Corset-Set-P7965.aspx but had some problems getting it uploaded through my Control Panel on Host Gator. All the directories were lined up correctly but the pictures weren’t showing up…anyways…I went back to Freeway and desperately need to know if there is an action that will do this exactly like the link enclosed. I have a code to do this but I don’t believe you can tweek the html in Freeway. Any help showing me how to accomplish this in FW would be greatly appreciated.
Kevin
Well, there goes any hope of productivity for the day.
Yes, you can do this, easily and entirely within Freeway. Get over to Weaver’s Action emporium and get one of the Lightbox Actions. There’s a paid one and a free one, and they both work very well.
http://www.coastalrugs.com/Actions
Thanks, Walter.lol Productivity has resumed.
Not here it hasn’t!
Productivity has stopped again.
I installed the action but it doesn’t work. I’m given a message when I try to preview it telling me I have to do something that I don’t understand. Anymore suggestions?
Thanks.
Tell us what message you are getting and we will try and help.
And which action you are using - moo:slimbox?
Here you go. This is the message I got. Actually posted the message here. http://i509.photobucket.com/albums/s331/ckdontes/Screenshot_10.png
I’m sorry…the action was lightbox.
OK - add the Protaculous Page action
Page>Actions>Protaculous
If you dont have it you can get it at http://www.actionsforge.com/actions/view/18-protaculous
And once you have added it - try again
Okay, still not getting it. I downloaded the action you gave and tried again but it still isn’t working. When I preview the page and click the image nothing happens. I’ll just walk you through it so you can tell me if I’m doing something wrong. I select the thumb on my page then select item/image/pic to lightbox image. In the actions box for pic to lightbox image I select the full size image. I don’t check anything else in that box. Only because I wasn’t quite sure what to do with Protaculous I selected Page/Page Actions/Protaculous (the only actions section it’s located is in the Page Actions). I then previewed in Browser. Hope that makes sense. Any help would be greatly appreciated. Thanks.
I went with what you had asked the moo:slimbox…works like a charm. Thanks.
Glad you got it sorted. moo:slimbox is the one I use, the only caveat is that it clashes with protaculous which is use by a lot of the built in FW actions like Attention FX, Sound FX and Transition FX so they cannot co-exist on the same page.
