[Pro] Need help installing bootstrap
So someone told me that this way would help create a mobile site without using backdraft. I am able to see my code so getting it is not the issue. Can someone help me to get this too work or somehow show me as I am new to mobile sites?
www.hgrantdesigns.com/bootstrap/index.html
Bootstrap will only help you to create a mobile site in the same way that a car will help you to get from Boston to New York.
Trouble is that you need to learn to drive first.
Yeah, I decided to just start over and use backdraft
