[Pro] Need Help With Inserting PHP into Carousel
I’m a newbie to webprogramming but I am working on a project using carousel. I have the carousel working and I have the lifestream working which pulls from twitter and feedburner. Now I want to add the lifestream which is in php code to show up inside one of the carousel panels. Can anyone give me some advice on how I can do this.
Thank you all for your help.
If Lifestream gave you some sample code, you could try placing it in a Markup Item on your page and see what happens there. You will need to change the filename of your page (in the Inspector) to end in .php rather than .html, then upload it to your server and look at it there (Freeway’s Preview pane will stop working entirely, sorry).
You can get a Markup Item into a single pane of your carousel by dragging it while holding the spacebar down. Watch the edges of your carousel pane for a thick blue selection rectangle to appear (this will happen when your mouse is over the pane). Once you see that, you can drop your dragged item and it will become a “child” of that pane. You can refine its location inside the pane after that using the mouse or the arrow keys.
