You can use Helvetica Neue (I do) just make sure you add Helvetica as
a backup for those that don’t have it installed. You should also be
aware of the syntax required for certain browsers, eg, “HelveticaNeue-
Light”, “Helvetica Neue Light”. You need to cover your bases for
Webkit and certain versions of Firefox. There are numerous tutorials
explaining precisely how to do this (Google Helvetica Neue or
similar). If you can’t find any post back and I’ll walk you through it.
hmm ok Dave what is graphic text? I only have photoshop which I do all my graphics. I am unclear sorry
and Todd I can use Neue for menu in graphic but not in HTML when I build drop down. even when I change link styles I can see it in Freeway but not the browser… which is strange…
You can use HN as graphic text in a Moo Accordion trigger but not in the accordion itself.
Graphic text is achieved by drawing a graphic box - click inside for a cursor and then enter your text and style it. You can use any font you like because FW will convert it to gif text on output.
There are disadvantages when it comes to SEO as it is not searchable, googlebot readable text - essentially just images.
Thx Dave
thats what I thought you meant… yes I changed font in graphic text in HTML accordion trigger boxes and submenu and it was fine until I looked in browser and it would not display… I think best thing is to design in PS and import, but then I wonder if Mootools will take import an image instead of graphic text…to make accordian…hm the complication
