I have always had this problem - must be an easy solution.
I have created a new master template in my site. But, the problem is, when I take an existing page that I want to basically duplicate but use the new master, I have to create a whole new page using the new template, and then extract elements - such as the body wrapper and its contents, out of the previous page, and paste into the new page based on the new template. However, what happens is for instance, the footer does not float below the body wrapper now, as it should, but sort of floats around the middle of the pageβ¦what can I do about this?
Ok. Heres the file: Dropbox - File Deleted - Simplify your life
Look at the third one down: you will see, the footer covers the bodywrapper. I cannot work out why, or what to do about it. The problem originates with the fact (as far as I understand) that if I want something linked to a new template, I basically have to βstart overβ a page using the new template, then pasting the material into new page. If I do that pasting, this is what happens. I am sure there is a simple reason, but I cant figure out why the footer is floating up like this.
And as a future note - when passing on a FW file like this it is essential that you File > Save Archive (and zip the archived folder).
What the Save Archive process does is to gather all the original media used in the project and bundle it together with the FW document and present it in a neat package so that whoever receives the project gets it complete and doesnβt have to Edit > Resources before they can preview it.
