Could someone please tell me how you achieve the effect of a small window popping up as in the following site, for example:
http://www.heyoka.eu/
It’s an effect that seems to be becoming increasingly popular, but was not in use when I last designed a website. Looking at the page source reveals the term ‘fancyzoom’, can this be done with Freeway?
Thanks for any help.
Yes FancyZoom has been discussed here before - visit this link FancyZoom - How? | FreewayTalk | FreewayTalk
And if you have any questions we will try and help you out.
Remember that if you have an example online we can see it helps because we can read the underlying code to help track down problems.
There is also this Main from LLE that gives some insight into FZ implementation in FW
Thanks for that D, it will take me a while to look through that. I’m sure I’ll have more questions when I try to implement it.
If you start at Louise’s About page About it helps
