I made an iphone site from the template and uploaded, about 2 hours later the site is not found anymore on the iphone only in my computer Safari browser.
Is this a limitation of the trail software or a bug?
If I purchase the Freeway Express version can also use the iphone templates?
Just to be clear, the only limitation in the trial versions is time.
The trial versions ARE the full versions, but with a time bomb. After
30 days, you have to pay or you can’t open the documents you have
created. There are no limits to the number of sites you can make, and
those sites will continue to work in any practical definition of that
term. You just won’t be able to edit the Freeway documents that
generated them without a paid version of the Freeway application (Pro
or Express) that you created them with.
On Oct 10, 2010, at 10:39 PM, RICKDO wrote:
Thank you for the reply David.
Strange, when I restarted my Iphone4 the page was showing.
So Freeway has an iPhone Template now. How do you upload an iPhone web? Can you use the same FTP settings to add to an existing server host? I want to put a simplified version of these pages on to iPhone:
There is a service from www.monomobo.com that provides easy to do ready made iPhone templates and there is a free service but do they also host it all? Would that be easy? I understand you need to make a new domain which is your exiting domain with the addition of iphone Using DNS Control and MX Record
