hi
been using freeway for a bit but now in need of some help with the newscycle action. if anybody has a demo file of how to implement would be most grateful.
Thanks for the prompt reply, using FW5.6. Just trying to decide wether to use carousel, scripty fader or newscycle for a project I’m doing. Carousel would be ideal but would rather try and fit something into a inline model. I’ll have a look at your demo and get back to you.
Might go with scripty fader as all I’m doing is having a preview within a html element of different photos come links to other parts of website, but when testing in firefox or safari the second frame on load shows below the main container and then after load goes into the correct position. The main element for scripty fader is the same size as the fader options. I have tried changing the main element size to no avail so I was just wondering would this work ok after I publish to site folder on server
You have to do real world/browser testing to see your pages as others will.
There are always issues as locally stored files are not going to be accessed quite the same as those on the server - should be faster locally but there are other factors.
Have you got server space set up? You can add folders to an existing site (whether FW created or not) to upload into for testing.
Unfortunately scripty fader does not work correct on publish, will have to read more about it or see if I can implement carousel to work in a inline model
Could you please post a link to a broken page, and say a little more
about the problem you are having?
