Could you post a link to the page in question? I can’t really tell more from what you’ve said here. (It sounds as though you did everything you should.)
On Oct 2, 2018, at 2:45 PM, P Gray via freewaytalk email@hidden wrote:
Thanks Walter.
I have downloaded HTTPS CDN Helper Action and added the Action to my Freeway Pro.
I then selected the main page and added the action. I can see the action under Actions… dialog box
I then saved and published the site, before uploading it.I also created a .htaccess file and added in the following text given to me my server hosts:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.XXX.org.uk/$1 [R,L]
Where XXX is the website.
And this once uploaded to the site displays the padlock so it seems to be secure.
When I remove the .htaccess file the site is no longer secure but it displays the newscycle.
The problem is that the newscycle still doesn’t work when secure. Am I missing something?
