Do any of the Lightbox actions make it possible to use next or back buttons in the images once they are enlarged?
Thanks…
Robert
Thanks…
Robert
Weavers MooTools implementation allows this but it is getting a rewrite just now and may not be available for a bit.
http://www.coastalrugs.com/Actions/
OK. Thanks. I may just use Weaver’s “regular” lightbox action for now and work around it.
Not in the ScriptyLightbox, but I think that Weaver’s Moo based ones do. Just remember–you can’t use those along with any of the Softpress FX Actions.
It will be on a page by itself. Just a slideshow.
I’m a little confused on how to use more than 25 images, though, in case I want to just use it by just clicking a main image and then cycling through all the images.
Robert
A little confused…
The free Lightbox Action says I have to have a library loaded (which it says I can have Action FX loaded on the page somewhere), but it still doesn’t seem to always work. Sometimes I just get a pic in new page without the lightbox effect.
Also, I can’t seem to get it to recognize a folder of images. The only way to get it to see more images is to add them individually in the Additional Images boxes.
And the Prev/Next buttons don’t show unless I hover over a certain area. Shouldn’t they just be there?
Thanks…
Robert
No that is the way that it is set up
You could probably change the CSS to have them available all the time though - have you got the page online?
No, it’s not up because I keep changing it!
I started another thread because I was suddenly having lots of problems with either lightbox action.
I think I finally got the free one (not scripty) to work on individual images.
I just did this on a job a couple of weeks ago and all worked fine. Don;t know why it’s suddenly a bit “wiggy”. I haven’t done anything differently.
Robert
If you have a working version in another document then why not copy and paste it into your current doc and then change the images and styling to suit.
