Hi all, I’m just about to start my first responsive site using Backdraft (thanks Caleb), so expect a few more questions to follow - exciting eh!
My immediate problem is that the client has a couple of typefaces that she’d like to use throughout the site and I haven’t a clue how to force these characters. I realise there’s the Caxton action and GoogleFonts, but again, wouldn’t know how to implement either.
Does anyone out there have a preference for which works the best, or ease of use, or indeed any other web font type thingy solution?
Many thanks
Erik
(Erik)
February 12, 2014, 12:38pm
#2
Hi Trev,
This document from Ernie helped me a lot!!
http://cssway.thebigerns.com/workbench/google-fonts/
gl
Erik
Richard
(Richard)
February 12, 2014, 12:45pm
#3
In my humble opinion, Caxton is the easiest to use. It’s pretty straightforward:
create a webkit of the font at FontSquirrel.com
within Freeway, insert the action somewhere outside the page
select the .css-file that came with the webkit
create a font set named after the web font (including the ’ ‘)
apply the web font to the styles.
It’s thàt easy.
Richard
Many thanks Erik, I’ll look at that one.
Trevor Reaveley
On 12 Feb 2014, at 12:38, Erik email@hidden wrote:
Hi Trev,
gl
Erik
And thanks to you for that also Richard.
It’s thàt easy.
Richard
Richard, Erik, thanks to you both for pointing me in the right direction.
I had a go at both and ended up going Ernie’s GoogleFonts direction - seems to work a treat.
