While trying to publish I experience an error message which says there is a problem with a file that could be damaged. There is a code: -26201:528:149
The only thing I think that it has something to do with some EPS files I imported. But they error message does not show always and its gone when I stop Freeway and start Freeway again.
There are several EPS images on my site, and how can I pinpoint the damaged one? If I produce PNG files (same drawings from Eazydraw) the results are not as sharp as the EPS ones. And that is why I chose to use EPS.
Does that mean you think the EPS file is to blame? These are the formats in which Eazydraw can export:
Vector- PDF, EPS, SVG, DXF
Bitmap- TIFF, JPEG
Web- PNG, GIF
Windows- BMP, ICO
App Graphics
DXF
Keynote
FAVICON
Thing is, I tried PNG but when imported in Freeway, it does not look that sharp as the original or the EPS. When I try gif and want to import this in Freeway, I receive an error saying the gif is corrupt. Drawings use transparency, so a JPEG is not suitable.
The now used EPS files are automatically handled as jpeg’s by Freeway, when previewed it results in not sharp images. In the inspector I changed this for PNG, these settings work fine and the drawings look like the original. This all would have worked fine for my, if Freeway did not give me these errors when publishing.
I opened them in the Finder, with Apple’s preview. I do not own Photoshop that’s why.
Yes they are online. On my site http://www.appadvies.nl. They are the colored ‘islands’ on my indexpage and separate on my footer, in the middle.
They are not layared. I drew the lines and filled them with colors. Then I exported them. Eazydraw then let you choose ‘no background’. It’s an easy way to create an image and never made a drawing in Eazydraw using layers. Though it is possible with easydraw. Do you suggest I schould try that?
I understand, but strange thing is that the Gif’s I made weren’t exepted by Freeway: trying to import resulted in a message saying the graphic image I am trying to import has a wrong structure.
Thanks for your help so far with this strange problem!
Thanks. I changed the images to PNG’s. Softpress aqknowledges that there can be a problem with certain EPS files when Freeway is installed on Snow Leopard. I can not upgrade my MacBook because its too old for Lion.
